cmaki
- sheboygan, WI USA
I've got a motor on one of our machines that I think might be failing but I'm not sure. Its a goofy german built thing that is running at 380VAC. Sometimes when it has a load on it the motor will stall and stop. sometimes it wont. Once and a while it will trip the motor overloads but normally it doesn't. One time while it was acting up I was able to get an amp draw of one leg. right before it stalled I got 0 amps. The very next run it shot to 16 amps and tripped the overload but the sound was the same. Is it possible that the overloads are failing without tripping? Or one of the phases in the overload is going bad and stopping the power on that one phase causing the motor to stall?
The machine is a panel saw for cutting long boards. The motor in question is the first small cut and the larger motor cuts the boards fully. The motors are moving so its hard to get a reading from the motor itself.
Or am I totally wrong and the motor is going? That was my first thought until I saw the amp readings.
