Hi
I'm wiring up some equipment for a pool
I have a filter and heater off the same 240v circuit
I also have a 120v circuit for a receptacle and pool light
The poolman mounted a ionizer. It has a switch to toggle either 240v or
120v. It's feed is a 18 gauge sjw chord. It also has an on off switch.
Can I hard wire this into my 240v 20 amp pump circ or 120v 20 amp receptacle light circ.
or would I have to change the wiring method or chord to 12's or add a
Male plug to the 18 gauge and plug it in.
Thank you
Thank you
