ron
- New York, 40.7514,-73.9925
250.118 allows EMT to be the sole equipment ground conductor (EGC).
Other than making sure the typical minimum raceway installation is complete, 10' sticks and set screw couplings, is there anything else special that needs to be done. If there is an intermediate pull box or final panelboard can, are grounding bushings or anything else required for the EGC to be adequate per minimum Code requirements?
