cmaki
- sheboygan, WI USA
I understand that OSHA/NEC requires 36 inches in front of electrical equipment. I guess I'm just looking for a little clarification. the clearance is required for disconnects but what about equipment panels. Example. I have a cabinet with doors that houses the motor starters, overloads, VFDs and everything else to run the machine. There is a shutoff on the side of the cabinet that turns off some of the power but not all. Does the front (door side) of the cabinet need to keep the 36" clearance as well?
Side question. How does this apply to disconnects located 15 ft up? We have a series of bus bars (forgive me if this is not the correct word) that several disconnects each. What is the clearance required for these? Are there any considerations for equipment located on the ground below them?
