FionaZuppa
- AZ
- Part Time Electrician (semi retired, old) - EE retired.
anyone see any issue (NEC code or other safety issue) in having four #6 THHN in a 2.25" radius bend (1" plastic conduit). the bend is 180 degrees. its single phase 240v (two pole + neutral + gnd).
the wire seems to bend ok at this radius, but its definitely at the end of min radius.
is this doc generally accepted http://www.usawire-cable.com/pdfs/BENDING RADII AND PULLING TENSIONS.pdf
