Eddy Current
I have never worked in the lineman field, but I've noticed that these days more and more poles that are being put up are metal. I was just wondering what the advantages of metal poles over wood are?
Which is more likely to get hit by lightning?
The ones located in Florida.![]()
Smart ass answer aside I bet it makes darn little differance as both will have grounded metal objects on them.
It seems like the metal ones are taller too.
The average lightning bolt is 6 miles long, although Cape Canaveral Kennedy Space Center has indicated some as long as 75 miles.
The Northeast Reliability Interconnect is a brand new 345kV line going in up here, and the majority of those poles seem are huge H-frame glue-lams.Mass / RI reporting in, no metal utility poles here all wood unless we are talking long distance transmission and even those are often wood.
You forgot the granddaddy of them all, Hurricane Andrew. After that, some larger prestressed poles are often round instead of the traditional square to offer less wind loading. One that comes to mind is the transmission line from Homestead to the upper Keys was rebuilt with round concrete.Here in south Florida prestressed concrete is most common for electrical distribution.
Traffic signals use either prestressed concrete or galvanized steel.
Aluminum is most common for highway lighting.
For hardened infrastructure there are some mega monster concrete poles. This includes distribution to essential facilities like hospitals, jails, EOC's, police & fire stations, etc.
Highways (traffic signals, signs) used to always be designed for 70 mph wind loads. After the storms of Charlie, Francis, Ivan, Jean, Rita, Katrina & Wilma that all changed. Even a single highway sign now has a pole that would hold a herd of elephants.
After those storms I remember one main bridge in particular coming into town had no lighting for about 5 years. Every year DOT would put the repairs out to bid but nobody ever bid it because everyone was so busy not only from the storms but it was concurrent with a building boom. As to replacing signs, that took years too. Today all the exit numbers are painted on the pavement for the benefit of mutual aid forces being able to know where they are on a map. Even when you work in a city, and work for the city, you think you know all the streets until one morning when there are no signs. Imagine being a mutual aid responder from halfway across the country and being told go here - do that. GPS is the savior today but still not everyone has them.
The point of all this rambling is that when it comes to what material is used for a given application, local perils trump capital & installation costs.
A cheap pole today could cost you a fortune tomorrow.
A better pole today means you still have a pole tomorrow.
As to transmission infrastructure immediately coming out of a power plant, I don't know of any built in the past 10 years. Existing is mostly iron. I don't know if there's any wood left around here or not.
