I have an equipment mfr. proposing that their equipment to be mounted in Cl I Div 1 Group D location is protected by an X-Purge system. The purge system is supplied by the same mfr, and consists of a small blower (mounted in the non-haz area), an internal pressure switch and time delay relay which energizes the cabinet loads once pressure is present for a sufficient period of time, and de-energizes loads when pressure is lost.
I need to take a look at NFPA 496 (which I ordered today) to understand the technical requirements.
What NRTL listings would normally be expected for a Type X purge system? Would it generally apply to the entire system (cabinet + cabinet components+purge system components) or just the purge system components?
