Type W to lug
chris kennedy
Miami Fla.
Retired electrician
I need to terminate 4/0 type W to lugs on breakers. Do they make a pin that set screws to the pin similar to a cam lock termination?
Thanks, poor Google skills here.
I'm pretty sure that the sleeve is "crimped" by simply tightening the mechanical lug.
So you can use type W Portable Power Cable 2/0. It is easy to afford and work same as 4/0. Nothing to worry for it. You can also take help from an electrician. He can help you to suggest the best for you.
