shockme28139
Ran across a situation today where I had 69 amp on the line side of this breaker and 111amps on the load side of the breaker. Never have seen anything like this. Is breaker going bad?
I used two different amp meters same out come. I have picture of meters with amp draw. Can't get them in the same pic because of the way they are clamped.
I'm a licensed master electrician since 1987. I been in the trade since 1971. Don't think a meter use issue is the problem.
Well, there's the rub. He says the load side is higher than the line side. So the extra current isn't "going" somewhere; It is "coming" from somewhere. (yeah, I know, semantics).If that much current was going places it shouldn't something would be melting.
With my limited experience
It is an interesting question for sure and hopefully one that more experienced folks then myself can answer.
With my limited experience I can't see how it can be anything other than a meter issue or meter use issue. :?
