Air bnb
wyreman
SF CA USA
electrical contractor
I have an apartment house here and the owner has three apartments
He is using one for renting out to air BNB customers
Requirements are as
follows:
Entry gate
provide electric door strike
With keypad entry
Combination code is to be easily changed for "hotel" guests
Match gate code system with a levered entry lock for the rental unit
The code should be easily changed and able to match the gate code
System should be robust and reliable
And "easy to install"????
I'm going to have to run some wiring for a valcom type intercom system anyway
My main need at this time is for direction to specify keypads / entry locks that are programmable and reliable.
Th
In belief, man can do anything
Looks like the wink system w a schlage might do most of this
have you considered a key card system that hotels use instead of a keypad?
most alarm companies can put in some kind of key pad or key card system. don't be reinventing the wheel if you don't have to.
yeah they wanted internet control: expire guest codes remotely.
i found a good way to get everything but that with old aiphone and a die grinder
the internet stuff works for everything but the keypad.
gave them some limited options
dont want to be reinventing the wheel... I was there when they invented it the first time!:D
Please explain "Air BNB" customers?
Requirements are as
follows:
Entry gate
With keypad entry
Th
I was going to say it must be a California thing then looked it up. I was right.
"At the time, roommates Chesky and Gebbia could not afford the rent for their loft in San Francisco. They made their living room into a bed and breakfast, accommodating three guests on air mattresses..."
Thus AirBnB was born.:blink:
http://en.wikipedia.org/wiki/Airbnb
-Hal
