adagys
- SW of Chicago
I am installing a 17 kw generator which will be located approx. 75 feet from the transfer switch. The transfer switch is located right next to main panel. I have run a one inch pipe and the original whip from the transfer switch to the generator has 3-#6 and 1 #8 wires with 5 control wires. Do I need to upsize the wires to #4 for voltage drop and can I run the 5 control wire in the same pipe? Also, would 14 gauge THHN wires be acceptable for the control wires?
