GerryB
- woodbridge, ct. USA
If you install a spa panel as a sub panel next to the main panel and it has the GFI breaker and provision to lock it out for service do you not need the disco out at the tub?
It is single family. The reason I ask is it is a service switch, correct?, not considered an emergency switch but for someone working on the tub. I was reading elsewhere if you have the means, in this example, to turn off the breaker and lock it out, you have accomplished the same thing, ie: the worker knows the power can't be turned on while he is working on it. In a discussion on transfer switches on this site I read similarly if you have a lockout for your main breaker you do not need a transfer switch. I don't know if either of these is code acceptable, but it makes a certain amount of sense. This tub I am looking at the HO cut it into the deck in a corner, walls on three sides, all of them less then 5'. I could put the disco around the corner, if you were in the tub you couldn't see it but from a few feet out of the tub you could.You may need a emergency disconnect if it is not single family.
