Where to purchase additional GFCI Protected / No Equipment Ground stickers?
DarylH
San Marcos, CA
Hi All,
First post here on the site. After searching the FAQ and some other general queries I didn't find an answer to this question so trying here. Not sure if this is the correct sub forum to post this in - if not, hopefully a moderator will move to the right place and let me know.
I recently purchased a home that was built in the '50s but had been renovated to replace all the 2-prong receptacles with 3-prong versions. Thankfully it does appear that each of the 3-prong receptacles, if not a GFCI itself, is down circuit from a GFCI receptacle.
My problem is that most of these receptacles do not have an equipment ground and I would like to label the receptacles accordingly. Because I didn't install them in the first place, I don't have a bunch of the stickers laying around.
I've done a number of web searches for where to buy these stickers, but apparently haven't hit on the right combination. Does anyone know a source for these?
It seems that many folks don't bother to use the labels that come in the boxes with the GFCI receptacles in the first place, but for my own reasons I do want to add the stickers - I just can't find a source for them.
Any hints are appreciated.
Welcome to the forum. Looking at your profile it would appear you have the resources to print these at work.
Good suggestion! I suppose one could find the right size sticky label paper and spend some quality time adjusting the fonts and spacing.
Thankfully I just received an email reply from tech support at Leviton. They're going to send me all the stickers I need free of charge. Can't beat that!
So it looks like I'm all set. Case closed.
