Form 7 vs Form 8 Conduit Bodies
woods95662
sacramento
Can someone explain the difference to me? I'm not finding a clear explanation on the difference. Some say it's in the cover and others say it's in the size of the body.
You can always remove and replace a cover on a form 7, but sometimes that becomes very difficult on other types of conduit bodies where the cover attaches to the conduit body that uses a screw into a tapped hole in the conduit body.
The covers seem to be the mystery. OCAL for example I have seen Form 7 and 8 bodies be either the wing or screw type and they don't differentiate between the 2 types in the catalog. I guess at the end of the day it's up to the manufacturer it doesn't seem to be standardized.
Thank you for your question woods95662
I took a screen capture from page 18 of our catalog and attached it to this post.
Our full Ocal catalog can be downloaded here http://tnblnx3.tnb.com/emAlbum/albums//us_resource/cat23_oc1_bookmarked.pdf
(requires Adobe reader)
I hope this information shows Ocal follows the industry standard of form 7 covers using clips and form 8 covers using screws.
Please let me know if I can be of further assistance.
like Augie47 said above you can see the real difference in the dimensions on this manufacturer's web site.http://www.cooperindustries.com/content/dam/public/crousehinds/industrial-products/catalog-pdfs/fittings/form7.pdf
The form 8 is biger for more volume cu.
I normally ordered form 8 as the standard and looked to a box if needing to go bigger. The shop would send out what they thought I needed regardless.
Interesting I have installed many form 7 and 8's and did not know it was an industry standard. I do the advantage to cover with clips, as it will always be able to be removed
