I think you mean panelized lighting control like Homeworks. If that is the case, the dimmer is not an outlet as it is just a Class 2 control device that is talking to the panel. The light outside would not need AFCI if the power is coming from the lighting panel directly to the light.Good morning.
in a scenario of a branch circuit in apartment that originates in breaker box, goes to lutron dimming panel with dimming module and then goes to outdoor patio lights, do I have to install afci breaker?
Thank you.
By the definition of an outlet in article 100 the Lutron dimming equipment would be an outlet.
Continuing down the side track with infinity for a moment:
Would you call the j-box that connects to a 480 to 120 transformer whose secondary feeds back only into the building wiring system an outlet? Where is the utilization equipment in this case?
Just a hypothetical question trying to clarify the application of the definition of outlet. Not directly related to AFCI at all.It may be an outlet, but unless it is 15 or 20 amp it does not need AFCI. And if you had such an arrangement where/how would you install AFCI anyway?
