Vanece
- Vernon, TX, USA
Hello, first time poster here. I have 85 of ABB's motor starters model 325 2.5-4A and the ambient temperature is too high for them during the summer causing them to falsely trip (above 104?F in TX). They are rated the standard 40? C from what I can tell on the product data sheet on page 5 (linked below). So my question is can anyone recommend a replacement that matches all the specs of this motor starter, but has a higher operating ambient temperature? I am a technician, not an engineer so while I could match the bullet points of another product I don't want to violate any code or safety aspects. I believe this is the correct forum for the question, apologies if not. Application is for a generator cooling fan motor on commercial wind turbines. There is also an HK-20 auxiliary contact that will likely need replacement with the new MS since they will likely be incompatible. Picture of current unit as is attached. Thank you for any feedback and sorry for the long post.
http://www05.abb.com/global/scot/scot209.nsf/veritydisplay/0015f49c150eb4d1c1257c7e0030dfca/$file/2CDC131046D0201.pdf
