Hey you guys, just wanted to know your feedback on this current situation that I have. I have two pumps in my plant, each pump must have a LOW LEVEL FLOAT so the pump will stop in low level. The panel that I have has only one input for one float. I had the idea to add a selector switch for LOW LEVEL FLOAT 1 and LOW LEVEL FLOAT 2 and connect it to that input and pick witch LOW LEVEL FLOAT I want to use. The problem comes when I want to use both pumps, is there a kind of switch that I can use for LOW LEVEL FLOAT 1, LOW LEVEL FLOAT 2 and BOTH in case I want to use both pumps and still want the control panel to stop when one of the Level is low? Se attached picture of idea. Thanks!
