MannyBurgos
- Waukegan, IL
Assuming you are saying that your 4th conductor is the Grounding Electrode Conductor to the water pipe, keep in mind, when you route that conductor thru your metal nipple you must bond both ends to the conductor. (250.64)(E)
Wouln't the r.m.c raceway between the main disconnect and sub panel satisy 250.64(e) regarding electrically continious from point of attachment (main) to grounding electrode (water pipe)?
