mason.dale
- Saskatoon SK Canada
Hi,
I work for a live production company. We build stages and roofs, we use big Lighting and Audio systems. my question is when should you use a grounding rode. i watched the you-tube videos, but since we work in very flat fields usually in the middle of nowhere where there isn't alot of other buildings. if there is a lighting strike and it strikes one of the towers that holds up our roof should there be a grounding rode in place in case of that? also in that situation should we also ground the generator to the same grounding rode or leave the generator without a grounding rode? if we are working in the city where there is a lot of other buildings should we leave the stage ungrounded in case of a lighting strike elsewhere?
Thank you in advanced
Timothy Mason
Timothy Mason
