PVC Coated
I didn't kow that. I thought it was paint.
ice
:thumbsup:
It is the main ingredient in one form of clear or translucent colored finish for wood, yes. And I suppose it could be a dip or spray coating for other products.
AFAIK it is not found much as a solid product.
I believe that it is used primarily as a solvent based product while PVC is melted/extruded with only a plasticizer and not a solvent.
Sure it's not polyvinyl chloride?
If the customer is concerned about abrasion and not just chemical corrosion, I can see a specification for polyurethane coated conduit, as described here: http://www.engineerlive.com/content/23527. The application called out there is for flexible conduit though.
Not very common, I guess since not everybody recognizes what it is and why it might be used.
Here is a supplier of urethane coated rigid, where the paint role of urethane (specifically the ability to add color) seems to be a factor: http://www.trojanpowder.com/process/mta.html .
Curious as to how to labor it.
