lbnuke
New member
- San Diego, CA, United States
This is intended to add to the Steel Structure Grounding thread here: http://forums.mikeholt.com/showthread.php?t=106239. The original thread has been closed.
When steel structures utilize structural steel for the path to ground (i.e. grounding electrical equipment to columns at each level, then perhaps corner columns at the ground level), how is electrical continuity maintained between the structural components in the ground path? Does a weld create an electrically continuous connection? Does a bolted connection? Does a bolted connection with a piercing washer? In order to maintain electrical continuity, paint and other non-conductive coatings must be removed per NEC 250.12. How is painted steel modified or pierced to electrically connect two separate steel members when delivered to site then painted in the field prior or post erection? Does steel typically arrive primed, stock, etc.?
