agolestani
- United States
Hi All,
So the code allows for a single line circuit to a detached garage without placement of a sub panel. I am also aware that a multi-branch circuit must be accompanied by a subpanel at the garage with 4 feeder wire, 2 ground rods,isolated ground and neutral, etc.
My question is regarding adding an additional single circuit line to a detached garage that already has an incoming single circuit. Is one able to add another single circuit run to this detached structure in order to avoid the Subpanel? Also would there be any difference in the answer if the garage were to house a Washer/dryer unit, thus having another metallic path between the house (where main load center is located) and the garage.
Please, and thank you.
