bdogwill7 Member Location SC Sep 11, 2014 #1 What is the min number of gfci breakers can be installed in a panel......
jumper Senior Member Location 3 Hr 2 Min from Winged Horses Sep 11, 2014 #3 480sparky said: 0 . Click to expand... Agreed.
charlie b Moderator Staff member Location Lockport, IL Occupation Semi-Retired Electrical Engineer Sep 11, 2014 #4 I agree that the answer given above is the correct answer to the question you asked. But I don't think you asked the question that you wanted to ask. Can you clarify your question?
Dennis Alwon Moderator Staff member Location Chapel Hill, NC Occupation Retired Electrical Contractor Sep 11, 2014 #5 I assume the op means the maximum number not minimum. I rarely use gfci breakers but you can have as many as the panel will accommodate
