Not subject to ADA. A conventional stat is usually at 60", it just seemed like that was too high.
This is true of most thermostats where the heat is intended to warm the floor only and there is a separate heating system for the room air.The height does not matter as there is a probe that has to go in the floor and that senses the heat
Actually, that would have been the exact same answer I would have given. :happyyes: Without doing any measurements, I would estimate the height of the controller to be around 48 inches.Mine is in the bathroom, and the control is mounted between the light switches and the outlets, on the wall left side of counter. Being w/ the other two boxes, same height is best in my opinion, and they are pretty much a set and forget control.
