Hello.
27 yrs in the house... lost power "Once" for two or three hrs last year.
Neighboring towns lost power for a week or two from hurricane couple years back.
If I were to lose power,
My concern is heat and "mainly" heat trace tape for a flat roof that has plagued me for years
I went for the Honda eu2000i for a small backup for house and maybe jobsite for service changes etc...
My main panel is 200 amp (main breaker panel) off an outside main breaker disconnect.
The eu2000i is 120v only.
I would like to back feed the panel, leave all 240v circs off. Keep a couple low amp loads like gas boiler, heat tape, fish tank on and and cycle through frig. freezer. and other loads as needed.
Was no biggy in my head, but I read something (that I can't locate now) that someone wrote in a review that the electronics of something he was trying to run wouldn't work because there was 60v on the neutral.
(I'm assuming that was neutral to ground, but after locating a schematic I see that neutral and ground are common so I can't see it or know what he was talking about)
page 56
http://cdn.powerequipment.honda.com/pe/pdf/manuals/31Z07610.pdf
Does anyone see the potential for voltage on the neutral?
On the unit I got, "if" there is voltage and also if I can't separate the neutral/ground bond..
would it be better to pull the neutral/ground lines off the bars in the panel?
Thank you
edit . just thinking if there is voltage (or even not). should I remove the house lines from neutral and ground, and bond neutral to ground at the eu2000i (via jumping a male plug with a neutral to ground jumper and inserting it in one of the eu2000's duplex receptacles)?
page 56
Thank you
