mbrooke
Batteries Included
- United States
- Technician
A cord and plug connected appliance, such as a car charger, is the current limit 100% or does the 80% rule apply for over 3 hour periods?
Continuous Load. A load where the maximum current is
expected to continue for 3 hours or more.
Are you referencing 210.19(A)(1) for the ampacity of continuous loads? 1/125% = 80%? Does your equipment fall under the exception for listed devices?
Well, unless it is a low power charger doing a 9+ hour total recharge of a Tesla Roadster. (The high current output period will last at least 3 hours and possibly 7 or more.)A car charger would not meet the definition of a continuous load as Bob stated since it will not operate at it's maximum current for 3 hours or more.
It would be at its maximum at least up to the point where the battery was 80% full, and even then would be reduced only as the battery temperature started to rise.You might be right, I was thinking a charger that was less intuitive and has the largest load when the battery is discharged but diminishes as the battery begins to hold the charge. But even in your example would it always be at it's maximum?
