Davebones
- North Of Tampa Fl
We had a area constructed last year that has some drying rooms for product . These were built and designed as Class 1 Div 2 area's . We dry product that contain alcohol in them . The rooms have a braided copper wire run around the wall's for doing any grounding with flexible ground straps .The contractor that installed this ran the braided copper to the building steel .  The safety department had a audit done and they have asked us to verify the the grounding is less than 5 ohm's .  They also said we should add a grounding rod for static .   ( 1 ) Would a clamp-on be the best way to test this for less than 5 ohm's ?  ( 2 ) If we added a ground rod in the room would this be a issue ?  Since we are in a high lighting area that's why I ask about location . These room's are designed for the roof to blow out just incase so any opinion's on this is very much appreciated ...
