mtnelectrical
- Essex, New Jersey
I was asked by a customer to install a couple of pull station in the common areas. He has hardwired smoke detectors in place already, so I was planning to get this relay module kidde sm120x and use it according to their drawing provided so when this PS is activated all the interconnected smoke detectors go off in the common areas. I went to the city building dept and filed an application for electrical and fire. Electrical Insp called me and said my application was denied because of the fire inspector. I talked to the fire inspector and he said that the wiring that I was going to do is illegal that I can not mix the line voltage with the pull station that he said that is not a ul approved way to use that relay. I have explained to the inspector that the module has a 9 vdc terminal that would be the one going though the pull station and not 120 volts, but he said that this way of wiring between these relays and pull stations have been classified as illegal wiring. Has any one heard about this before? Sorry for the long post.
