- Licensed Electrician
Use the plugs that come with the Al boxes then.
			oh, let me clarify, i will set the top of this plug at the top level of the pour, etc. concrete hardens and then i swap out this set for a new set, etc.
You are making something that is very easy into a big project. :lol:
not really, was looking at the options. i am using std white PVC 1/2" slip to npt coupling with std slotted coin buttons, a touch of silicone on the coin threads and then a tad of silicone across the top so concrete can be floated right over the top (top will be flush with concrete, etc). a few days after the pour i can take out the coin buttons and replace with new ones painted to match the colored concrete, etc. i think this is the best option, allows the conduit to be plugged in inconspicuous way, extended as needed, and used for wires as needed.
thanks all for the input. this toast is done.
What he described is a PVC to female threaded adapter, he may not know that they make them or can not find versions that are listed for electrical use.White PVC fittings are not listed for electrical. That is a plumbing fitting.
Are you running white PVC for the electrical with plumbing 90? fittings?
yes, i had the gray electrical ones in my hand, then switched to white. the white fitting is a tad beefier and a tad flatter on top than the gray ones, etc.
the conduit is for speaker wire.
