Heated Air Curtain
jusme123
NY
JW
In an industrial factory, does a 480v, 3 phase, 40 amp circuit that supplies a heating air curtain (mounted above roll up doors) need a disconnect, or can the breaker serve as the disconnect? I have been looking for the code article but can not find it.
doesn't that cover electric heat, the 480v is only for the fan motor , heat comes from hot water piping?
true, its just one of those standard air curtain units mounted above roll up door , albeit a large one, with hot water heating pipes going into the UL Listed unit. I said it needs disc..
