Please note that this question is related to equipment installed under the '08 Code as later Codes have some changes:
I have a sandblast machine newly installed in an industrial facility. There are 30 motors associated with this machine. All the motors are controlled from a central motor control
assembly which is equipped with one external disconnect. The individual motor starters are supplied thru individual (one pole) din-rail fuse disconnects within the control cabinet.
The motors do not have individual disconnecting means. The facility is taking the stand that their lock-out/tag-out procedure allows this install.\
As I read 430.102 ('08) the LOTO provision only applies if the controller disconnect means is individually capable of being locked out.
I do not feel this install meets the requirements to allow the absence of individual disconnects in sight from each motor.
Comments ?
Comments ?
