I got a panel where I am getting some wierd readings. With the panel off the voltage reads 120 l1-n and 240 l1-l2. When I turn the panel on I get 240 on l1-n which tells me I got a neutral problem. The strange thing is that when I pull certain fuses the problem goes away and if put some other fuses back in the problem returns. It's a bunch of different circuits that is causing the problem
