electricalist
- dallas tx
Meter 2"" ridged nipple to panel bonding bushing in panel, ground is a egc? If the conduit can be a ground can from the bonding bushing to the main panels ground / neutral bus be just a jumper? If the ground is correct for size?. In odessa the meter must be bonded by egc. . In dallas they will not connect power if there is any conductor (ground ) landed at the neutral. It seems that at the main panel there is a bond that will include the meter if assembled correctly. Odessa requires an actual wire. This to me seems like a parallel path for neutral. From main panel back to meter on neutral then again on ground. Is this electrical corruption?
