mkgrady
- Massachusetts
I need to splice an RG59 cable that was accidentally cut. It is for a camera system. Is it as easy as putting new F type terminations and screwing them onto a threaded connector used for RG6? I tried that already and it did not work. Maybe it was the push-on connectors or the twist on connectors (I tried both). I thought both seemed like a bad connection. I could not get the signal to go through the splice. I'm going back tomorrow with the snap and seal F type type tomorrow. Should this work or am I using the wrong parts?
