Situation is an 11 unit apt. multi-family building. The smoke detectors throughout all units are on a single common circuit originating from the house panel. All of the smoke alarms/detectors are interconnected in each individual unit only. (ie.... unit A is not interconnected to unit B ect...)
What is the code issue with 120 volt devices (smoke detectors) in the individual units not fed from the sub-panel that feeds that particular unit.
Is there a violation somewhere? What is the code section? NEC, UBC, NFPA 72 or others?????
Notes:
the tenant has access to the house panel.
AFCI protection provided
OCD marked red and locked on per AHJ
hard wired with battery BU
wiring is code compliant.
detectors in proper locations ect .....
location CA, Los Angeles Dept. of Bldg. & Safety
Reasoning of Install:
local FD and AHJ want SD's and CO's in all units however, all units do not have power (vacant no meter).
POS property built 1950's , last permitted work pre 1988.
Please state code references and year.
I completely understand the safety issue but I need a code reference. I know its there somewhere.
Notes:
