Ok, so this one should be easy.
I have a standard 3 phase scroll compressor (460/3/60).
I would like to find out how many kW it is using (roughly, doesn't need to be exact). Pretty much just trying to estimate cost to run per hour.
Using watt's formula, I have Watts = Vavg * Iavg * PF * 1.732
The plan is to just grab a fluke clamp amp meter, measure each of the phases, and take the average. This would give me Iavg.
For Vavg, I am just going to use 460, since I do not need to be exact.
Not quite sure how I would take measurements for PF, but it's probably around .9, right?
Then, I would just plug into the equation, which will give me watts. Divide by 1000 for kW. Then multiply by 0.12 if we pay 12 cents per kWh.
Does this all make sense?
Thanks!
Thanks!
