DougChris
- Rockford, IL USA
A question regarding legality of an old split bolt connection ahead of two main breakers in distribution panels.
I have come across an old 480V 3-wire service where the incoming service conductors are 'tapped' using a split bolt before the main breaker of two separate panels. The service entrance cable is 4/0 to a 325A main breaker while the 'tapped' connection is 350kcmil to a separate 200A main breaker about 15 feet away. The attached pictures show the first 480V panel where the splice or 'tapped' connection is made with taped split bolts. I would like to know if this is code compliant?
