SirScott
New member
- United States
I came across an electrical print for a machine that has two sources of power entering it. A 208V 3phase with neutral feed into the enclosure via a disconnect switch with 3pole circuit breaker and then a 480VAC 3phase via a contactor followed by separate 3pole circuit breaker. The contactor coil is powered by the 208VAC circuit such that if you open the 208V disconnect switch, the 480V circuit contactor opens. I hadn't seen this done before so I have searched my NEC book and searched online, but have not found a definitive answer if this is legimate. Can anyone shed some light on this?
