Gutter Tap's
mstrlucky74
NJ
When running riser feeders and you have to tap the feeder in the panel "gutter" what kind of taps would you use? Would an Ilsco multi tap connector be okay?
That ONE tap would work for a run with 4 wires?
That one connector is good for one feeder wire per one feeder tap wire.
If you have multiple sets of feeder wires (i.e. paralleled feeder), you will need to use something like the PTA Multi Tap series. Go to the page linked earlier, and navigate 'back' one level... just under the page title.
