Strahan
- Watsontown, PA
I'm currently working up an estimate for a customer who has installed a tankless water heater and needs electric run to it. His main service panelboard is full. I want to istall a 100amp "sub-panel" in order to provide enough room for the water heater. I'm finding lots of reference to panels installed at separate buildings but not necessarily same building. I'm treating this as a feeder and the panel will not be very big circuit number wise. I know to keep the grounded conductor and EGC separated at the feeder panel, but should I also run a bonding wire to the water heater since this panel is feeding it? I'm pretty sure I do.
Also, does the feeder panel require a main OCPD? reading 408.36 I'm thinking as long as the panel is rated for 100amps and is less than 42circuits which it will be I don't need one. Before anyone talks about load study being done I have looked at what is currently there and his main panel now is a 200amp but very small in number of circuits. Instead of replacing the main panel with a bigger circuit one the homeowner is requesting a feeder panel be installed. He doesn't want to go through the hassle of dealing with replacing the main panel. Any help would be appreciated. Thanks!
