The application is a Grid-tie system on a flat roof with the inverters on the roof, the question is regarding the conductor from the inverter to the array, EMT is ran from the liquid-tite at the inverter to the array which is used to protect the PV wires(dc side) & the EMT has a connector & bushing on the end for protection.
(The EMT is basically a sleeve & the conductors are open to the atmosphere under the modules)
A ground wire needs to be pulled from the inverter to the array, some have indicated using bare # 6 Copper stranded & others indicated green THHN/THWN-2 is allowed & some have indicated THHN & at the end where the conductor is exposed to the atmosphere, just remove the insulation therefore leaving the bare copper exposed.
Thank you for your input.
