J
jonny1982
Guest
So say I have a 112.5 KVA Transformer. The primary is 135 amps (480) and the secondary is 312 amps (208). Am I thinking of the following right?
If I wanted to get the max out of it, I would get a 150 amp breaker for the primary and size wire proper for this. Then I would feed a 300 amp panel for secondary?
Lets say I only needed a 250 amp panel off the secondary. That would change the minimum size of the primary, right? What is the calculation for this (is there a ratio multiplier?)
Thanks
Thanks
