Hendrix
- New England
Is there a minimum size that would mandate a generator to be separately derived?
Ironically...here is a ok article on the subject which you might like that explains in more details as I became too lazy to type a full explanation (after lunch my belly is full and I am lethargic.)
http://www.mikeholt.com/technical.p...ms [Transformers, Generators, etc.] (4-10-2K)
I thought that I read somewhere that anything above a certain KVA needed to be separately derived.Nope. Why would you ask, if I may ask?
What you probably read was the discussions over UL 2201 and some of the changes in 445.11 for markings and 445.20 for GFCI receptacles on 15 KW or smaller portable generators.I thought that I read somewhere that anything above a certain KVA needed to be separately derived.
