Would like some thoughts on disconnecting means for double wall oven. Ovens come factory installed with FMC installed for wiring into a j box. FMC is only long enough to get to a j box located in the cabinet under the oven. A 2 pole breaker lock is about the only way to provide a disconnecting means. Would it be a code violation to remove the factoryFMC and install a 4 wire cord?
