I need to install a 240 V heater (5kw). Owner wants it on a timer so that it only runs at a particular time in the early morning hours.I am debating if I should use a DP/ST time clock(T104) or control it through a definite purpose contactor.Is it common to use time clocks for other than say lighting loads? Rating of clock is 40A, 20A or there abouts will be max draw on the unit. Suggestions appreciated.
