jengrahm
- Dixon, Ca US
I recently inspected a 125 amp residential panel with a 6.6 KVA photovoltaic system. It has a 100 amp MCB, and is feeding 2 separate photo voltaic inverter's with 20amp/2 poles. The photo voltaic load side breakers are located at each end of the buss bar, with MCB in the middle. is this acceptable? I know that usually with a center fed panel that the 120% rule now becomes a 100% rule, but does this still apply with a P.V. CB on either end?
