IN an earlier post fmtjfw pointed out the following:
UL White Book 2013 ZKST Thermoset-Insulated Wire and ZLGR Thermoplastic-Insulated Wire:
Wire and cable employing compact-stranded copper conductors is so identified directly following the conductor size, wherever it appears (surface, tag, carton or reel), by ??compact copper.?? The abbreviations ??CMPCT?? and ??CU?? may be used for compact and copper, respectively.
Tags, reels and cartons for product employing compact-stranded copper  conductors have the marking: ??Terminate with connectors identified for  use with compact-stranded copper conductors.??
AL wires are also in the same sections.
