MasterTheNEC
CEO and President of Electrical Code Academy, Inc.
- McKinney, Texas
- CEO
Not when the ground water coming in is 40 degrees. Based on one manufacturer's rate of rise to achieve 130 Degrees F (what mine is set on). If the water heater is depleted so that the total incoming water is around 40 degrees. The manufacturer of this specific water heater (4,500W) would be roughly 14 degrees per hour. Thus it could (in conceivable theory) take well more than 3 hours to achieve resumed storage temperature and thats not even counting if someone uses it while it is in recovery....But to your point...I have NO IDEA how we got on Water Heaters...:angel:Yes you are correct.:happysad: An electric water heater will heat ground water to 120? in less than an hour with the standard 4500 watt elements.But why are we on water heaters?
Below is a Rheem Rate of Rise Temperature chart that is handy, I guess it's handy...for something.:ashamed1:
http://www.rheem.com/docs/FetchDocument.aspx?ID=6e52d38f-9680-44dc-90af-dd6984c8a7d6
