A admiralporklung Member Location Front Royal Nov 10, 2014 #1 For the purpose of estimating, is EMT with compression couplings sufficient for a car detailing garage where power washers will be used? Thanks a lot.
G GoldDigger Moderator Staff member Location Placerville, CA, USA Occupation Retired PV System Designer Nov 10, 2014 #2 Are they going to spray the walls the EMT is on?
L lakeview100 Member Location Chicago, IL Nov 11, 2014 #4 Rigid pipe was Spec'd in the car wash I recently bid. Admiral, what happened with the Movie Theater job?
Sierrasparky Senior Member Location USA Occupation Electrician ,contractor Nov 11, 2014 #5 Sure if you use the proper connectors and couplings. The only thing I wonder about is your junction boxes as some say that the EMT connectors are not rated with bell boxes, I don't agree with that though.
