Kind of a basic question but never ran into this before. Just went to a house with a hot tub located outdoors. Existing panel has a 60A/2P CB feeding the new hot tub panel. The new hot tub panel is one of those "all in one" kits that comes with the 2 pole GFCI protected circuit breaker. The feed from the panel to the hot tub panel is (2)#6 Cu + EG (no neutral). I know a GFCI does not need the neutral on the load side to function properly but I would think there should be one from the panel to the hot tub panel. The only question is, where does the neutral pig tail from the GFCI breaker terminate? Only place I can think is under the neutral bus which will not be connected to anything.
The hot tub doesent require the neutral to operate.
